Old 06-24-2003, 07:09 PM
fspandorf fspandorf is offline
See Attachment please. I give up on the attachment.
FFR Cobra Kit
FFR 427 Kit 10,890
Hood Hinge Set 115
Chrome Bumper Ass 650
Raydot Mirror (2) 70
Polished Aluminium Mirror Mounting Brackets 35
4 into 4 Headers w Side Exhaust 425
Oil Cooler 350
Boady Cutouts 100
IRS 1,900
Crating and Shipping 1,360
Wing Windows 150
Taneau Cover 300
Convertible Top 1,100
Polished Aluminum Roll Bar Grommets 80
Polished Aluminium Brake Handle 30
Polished Aluminium Windsheild Defroster Plates 17
Vintage Heater w custom box 225
Custome 5 core radiater 340
Seat Tracks 70
Engine
351W Block 300
Machine Shop Block Work 190
Coast High 427 Stroker Kit with custom Probe pistons for 9.7:1 CR 2,291
Stage 1 Victor Jr Head Kit 2,106
Cam Bearing and Water Jacket Plugs 51
Mallory EFI Distributer 232
Stuart Water Pum & Thermostat 92
Melodian High Volume Oil Pump 39
ARP Oil Pump Shaft 17
ARP Oil Pump Stud Kit 5
ARP Oil Pan Stud Kit 32
True Roller Cam Thrust Bearing 63
Cloyes True Roller Timming Gear Set 74
Convertible Engine Mounts 65
Canton Oil Pan 260
Aluminium Power Steering Pulley 82
Serpentine Fan Belt 24
Extra Long Throttle cable 36
Moroso Water Filler 24
Transmission
Throwout Bearing 20
Pilot Bearing 10
Driven Disk 141
Pressure Plate 109
Tremic TKO Transmission w Steel Bellhousing 1,557
Custom Drive shaft and Us 87
Rear End
Pinion Seal 10
Axel Seals 20
Rear End Carrier Shims 40
Limited Slip 174
Lincoln Complete Rear End 480
Brakes
Lincoln Front Brake Rotors 38
Steeda SS Brake Bushings 34
High Performance Brake Pads 55
Mustang Brake Hydro Booster 225
Custom Hydraulic Lines for PS/PB 257
Rear Lincoln Disk Brake Caliper 70
Rear Brake Machining for 5 Lugs 80
Fuel & Air System
High Volume Replaceable Fuel Filter 37
255 LPH Fuel Pump 125
TFS custom machined Intake to fit under hood 475
Intake Gasket 20
87 mm Chrome Airmeter 260
Accufab Polished Throttle Body 90mm 260
Custom Machined Throttle Body Spacer 165
36 Lb Fuel Injectors 350
Ford EPIC Computer 1,000
Used K&N Air Cleaner system 35
Earls Fittings 356
1/2 inch fuel rails 145
Electrical
Autometer Phantom Guages: Tach, Speedo, Oil Pres & Tmp, Clock, Fuel, Vac, Volts, Wtr Tmp 635
New high toque starter 99
New Battery 60
Auto Reset Turn Signal Assembly 150
Electric fan Switch 43
Back up lights 45
Miscelaneous
AFS Chrome Cobra Wheels 9x17 F, 10.5x17 R 1,381
Moroso Steering U Joint 60
1989 Ford Mustang 1,200
Car Chemistry Exhaust Inserts 57
Faulken Z Rated Tires 255x40x17 F, 314x35x17 R 320
Engine Hoist w Balance bar 229
Engine Stand 79
Pop Rivit Gun, Pneumatic 35
Total 35,218
I would like to get close to 25K so I can pay off the loan I took out to build it and pay off the wife.
Fred
