Old 06-24-2003, 08:59 PM
msinghof msinghof is offline
Cobra Make, Engine: SPF 1557, Southern Automotive stroked 427 Top-Oiler (C5AE-A), 550hp, TKO
Question Need 427 Oil Pick-up Gasket P/N
Is the oil pick-up tube to pump gasket a common Ford p/n? Have a 65 C5AE-A 427 top oiler and in the process of replacing the oil pan gasket I had to remove the oil pick-up screen and windage tray. This is the small diamond shaped gasket with two mounting bolt holes and one center hole. Appreciate any input. Thanks!
