Old 06-25-2003, 07:08 AM
fspandorf fspandorf is offline
Not titled or registered yet.
Body is on.
Dash is loaded with guages but not wired to car yet. Most of lighting is wired even though some lights are not mounted as the car needs painting.
The transmission tunnel cover is not mounted.
The splash guards are not mounted.
The seets are not mounted.
The soft top and tanneau cover are not fitted
The windsheild is drilled and located but not bolted.
The carpets are not in.
Side mirrors not on.
The custom battery trunck battery box cover is not yet fashions. Needs two flat peices of aluminium with piano hinges to allow uncovering battery.
The car is in its final stages as you can see.
I am working on those pictures.
