Old 06-27-2003, 06:16 AM
speed220mph's Avatar
speed220mph speed220mph is offline
Cobra Make, Engine: ERA 427SC w/427so, ERA GT #2002
Lakewood knows they have a problem, so they sell offset bushings for you, the customer, to correct their product.
When you're set up to check bellhousing runout, check the rear surface of the bellhousing to make sure it's parallel to its front face. If these surfaces aren't parallel, the transmission will be cocked in relation to the crankshaft, causing the transmission to jump out of gear.
As with the dowel holes, these surfaces should be square, but frequently they aren't. The only way to correct this problem is to rig the bellhousing with shims or remove the bellhousing and have it surface ground at a machine shop. While at it, I would overbore the dowel holes, insert them and rebore them to make the holes accurate.
Tom
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough HORSEPOWER." Mark Donohue
