Old 06-28-2003, 12:34 PM
Jamo's Avatar
Jamo Jamo is offline
Super Moderator
One other item to check with regard to heat. Sometimes, the lower firewall access panel is not bolted in at the top because the carpet holds it in pretty tight. I was still getting a great deal of heat from there, and bolted it up (two)--really made a difference. Tom even suggested some screws at the bottom, but it was tight enough with the folded over carpet in that area.
The air vent on the driver's side REALLY helps.
Jamo
