It is some crud in your needle seat, exactly as stated above. Remove the 4 allens and clean the bowl/needle assembly out. I would recommend that you order a few red "permanent" float bowl gaskets first, from jegs.com
My gasket was trashed upon removal, and I ran around for a few weeks with the secondaries cut off because of the danger from the afore-mentioned "gushing". All is well now
James Madison, father of the Constitution, said, "If Tyranny and Oppression come to this land, it will be in the guise of fighting a foreign enemy." He also said, "No nation could preserve its freedom in the midst of continual warfare..."
http://www.standdown.net/index.htm
