Old 06-29-2003, 08:08 PM
msinghof msinghof is offline
Cobra Make, Engine: SPF 1557, Southern Automotive stroked 427 Top-Oiler (C5AE-A), 550hp, TKO
Unhappy Replaced All Gaskets...Still Leaks
Thanks for the input. Felpro makes cork pan gaskets and their product also includes the pump pickup gasket. Anyways, the application requires two pan gaskets with the windage tray and the end result is...still leaking at the bolts. I think my mistake was running the bead of RTV to the outside of the bolt holes instead of the inside. Will try it one more time.
