New kit to move the shifter forward
I spoke to Shafi at Keisler Automotive Engineering and they said they are coming out with a kit this week that allows the shifter to be moved forward for $350.00. If you want a hurst shifter modified to fit on the forward location they charge $299.00 for that option. The way theirs works is they put the shift adapter in between the shifting shaft which allows you to use the rear shifter location again if you want to and it also uses the existing reverse lockout switch.
SnakeBoy
SnakeBoy
