I'd be interested to see if anyone has an answer to this. I just tried to install my shifter boot (std. cobra boot and trim ring) over my Pro 5.0 shifter and the boot and trim ring will not fit over the two bolts that are designed to limit the throw of the shifter (the bolts that are at 12 o'clock and 6 o'clock on the shifter). Has anyone else had this problem? Is there a bigger boot and trim ring that you can use or should I just cut down those two bolts somewhat?
Replica is not a dirty word.
