Old 07-01-2003, 12:20 PM
bittentoo bittentoo is offline
Cobra Make, Engine: Unique 427 SC on order, 351c4v and top loader for power. And did I say that it will be Orange with white stripes?
Chifo,
I hope that the easy fix will cure your cleveland problems but I have my doubts. As been mentioned several times in this thread, I too believe that you have one of the head gaskets on backwards. How do I know? Because I too have made the same mistake. It is VERY easy to put one on backwards on a cleveland even though you are being very careful. I almost put the head gasket on backwards on the last cleveland that I built and I knew what to look out for!
If the motor was just running hot, woukld think that you had a cooling problem, but puking the water out tells me that there are other problems.
Good luck
Kelly P. Mullins
