Old 07-01-2003, 01:43 PM
Clois Harlan's Avatar
Clois Harlan Clois Harlan is offline
Here is an easy way to bleed the air out of your system. At the temperature sensor that is located just behind your thermosat, loosen the brass fittings. Start your engine and as your coolant circulates it will force the air out of the engine at the top of your manifold (sending unit sensor). Once the water starts to flow out of your sensor tighten it back up and then turn your engine off. You may need to do this once or twice to purge all the air out of your system. Do this with a cold engine. Just like bleeding your brakes.
"Let's roll"
"Be part of Something Good
