Bennett Automotive cost the former owner of CCX 3152 almost 10k in botched repairs and ultimately a blown engine (427 side oiler) due to the missed dianosis. Long story short the car I own was worked on exclusively by Bennett Automotive when it was owned by Rich Smith.
The car developed a short at the regulator / starter selonoid at the primary power source. The ignition worked but had an intermittant short on #2 and #3 cylinder. The higher the rpm the worse it was.
Repairs included $350 compression test, new alterntor, regulator, battery $1000. Carb adjustments (3) at different times $375. Valve adjustment $250, a "new" distributor (a used C3AE was installed) $500. Ultimately the former owner out of frustration and ignorance let the problem go and fragged a 427 side oiler short block which Bennett Automotive replaced witha plain jane 428 for $2800. (short Block)
The problem was still there when I bought the car, it hadn't run right in 5 years and the owner ran out of money to fix it. The whole problem and how I fixed it in about 4 hours including diagnosis is here in the forum.
I have never been to Bennett Automotive. It is likely I won't be going there for anything I will ever need given what I know.
michael
A man that is young in years, may be old in hours, if he have lost no time. But that happeneth rarely. Generally, youth is like the first cogitations, not so wise as the second. For there is a youth in thoughts, as well as in ages... Sir Francis Bacon (1561-1626)
