msinghof You are using the wrong RTV to seal an
oil pan. Get spray Hi-Tack, and clean both surfaces with brakekleen. tighen bolts to 15 inch pds. and let dry overnight. Fill with
oil and road test. Do you have a PCV valve on your motor?? If the motor builds up to much pressure inside, you will keep blowing gaskets until you get the pressure problem under control. Rick Lake
