here are all the part #'s I have, on the block right side front inverted 87 352, on piston sidewall front right 12 DIP, inside
oil gallery 427 26, on rear of block P 66-427, pistons C5AE-6110-AU, heads(numbers are cast into heads, why two different numbers, don't know, but that is what is stamped into heads) C4AE 0D10 6090F , other head C4AE 130 6090F, intake valves C8AX-6507-A, exhaust C8AX-6505-A, the rods are B7's. this should bring this to a close, you have the numbers. I am finished with this. at this point not willing to sell it to anyone in here, don't need your money and don't like the abuse I have suffered here, hope you are satisfied now. keep your money and I will keep my motor, even if it is only worth $ .10 it's mine. I'll use it as a bird bath. not one person has said, hey that's a nice car you built, mine is just as nice as any I have seen here, and it's not just my opinion, I have taken first place in two car shows and the car is not finished yet and it is my first build, not bad for a first at this, wait to you see the second. all I have recieved here is criticism and abuse, I don't need it and don't tolerate it. GOODBYE. Super Kit
