again here are all the part #s on the block right side front inverted 87 352, on piston sidewall front right 12 DIP, inside
oil gallery 427 26, on rear of block P 66-427, pistons C5AE-6110-AU, heads C4AE 0D10 6090F , other head C4AE 130 6090F, intake valves C8AX-6507-A, exhaust C8AX-6505-A, the Rods are B7s, only number on them. the rod cap is .865 wide, the bearing is .735, no numbers on them.
