Old 07-05-2003, 08:44 AM
Rick Carnahan Rick Carnahan is offline
That is true. I did the set up pryer to pulling the body so I could have the motor and pipes on the car and done then drop the body back on. The mounts I used were a set of semy solid(for my 5.0drag car) I had in the shop and they woud mount on eather side of the motor moving it an inch front or rear, I also needed them with the motor in the rear most position. I am not 100% sure that they match the mounts you will use. I am also running clevland heads on my 351w so also using the 351c headers. I am not sure if all of this will make my set up differ from your's
