Old 07-06-2003, 08:49 PM
Trueoo7 Trueoo7 is offline
Cobra Make, Engine: Backdraft, 302, Tremec 3550. #038
Default Rearend troubles
I have a new BDR with only 39 miles on it and I have developed a leak in the rear end already. It seems to be coming from a plate above the fill plugs. There is some sort of electronic sensor in this plate that has two small wires leading out of it that have been cut, presumably because it is not used for anything.
What type of BMW rear end is in this car and would you know the capacity because I will need to fill it again. Also will tightening this plate take care of the problem or will I need to remove it and replace the seal around it.
Thanks for any help you can lend.
Trueoo7
