Old 07-07-2003, 04:23 AM
trularin's Avatar
trularin trularin is offline
Member of the north
Cobra Make, Engine: A Cobra
Default PCV
Most engines these days need to have PCV.
If the engine is fresh, you will burn oil for a short while. The oil you are getting on the valve covers is oil blow-by.
Put a gromet in one of the openings with a baffle behind it and plug a PCV Vavle in it. Run a hose from the valve to the vac. inlet at the base of the carb. Adjust carb.
Just my $0.02
Hope this helps.
