Old 07-07-2003, 12:41 PM
Ron61's Avatar
Ron61 Ron61 is offline
Post
I think if you re-torque the heads the correct way is to back all the bolts off a little then re-torque them to the correct specs. However before I did this, I would make sure my temp. gauge, sender, and wiring are ok. Does the car smell hot ? At speed on the highway, your water pump may not be moving the water enough. Do you have to add water ? Fixit and some of the others can tell you a lot more than I about what to look for, but check the easy stuff first.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
