  #21 (permalink)
Old 07-08-2003, 06:58 AM
terry lee's Avatar
terry lee terry lee is offline
GEAR GRINDER CUM LAUDE
Cobra Make, Engine: SPF #1560 w/ Ford Racing [RDI/AFR/RPM] Alum. 427CI - 575HP & TKO
Default I'm about to order these
If you would please,
I would like to ask afew question before I call and place my order for these tires. I have a new set of 15" wheels, so I am interrested in the Good Year "Cobra" 26.5"x 15" slicks.
1. Has anyone used them in Autocross? I plan to use them for both autocross and open track events.
2. Do they warm up fairly quick, and retain temp for next run?
3. Did you have tread cut into them (for autocross), or run just plain slicks?
4. Do you need to run tubes, and if so, do you recommend the expensive racing tubes? Any problems running tubeless?
5. Has anyone found them other than from Rodger Kraus Racing.
6. How does one gracefully go into a tire store and ask to have tires mounted and balanced on your rims when not buying tires from them? This may sound really funny, but I have never done it.
Thanks
TL
BOYZ and TOYZ
With every day I grow alittle older -
BUT, I'LL NEVER GROW UP!
