07-09-2003, 03:14 PM
KY
That's a really high lift cam, but the duration isn't bad if you consider a 114 degree lobe separation. I don't think you would have much problem with it though. If you decide to change make sure your piston-valve clearance is good....plus make sure your valve springs will hold up to the lift and not coil bind.
