A couple of these posts indicate a vertical difference of 1/2" between the MII and late Mustang rack. I believe there is also a 1/2" horizontal difference (MII is 16" on center, late Mustang is 15 1/2" on center) in the mounting.
It would seem that offset bushings might accomodate the horizontal mount but not both, risking introducing bumpsteer. Has anyone done this conversion (MII to late model) and if so did you run into any problems? My MII rack has a 4 1/2 lock-to-lock, which seems slow, whereas the late racks are closer to 3 3/4. Any thoughts or suggestions?
