Guys, Thanks for your comments. I would like to ask Rick Lake if you could give me some info on changing the pump spring. I would like to try this. Mr,Fixit your assurance about 50psi being adequate was good to hear. I'm new to all of this and trying to learn. I would like to ask you, does
oil pressure in these FE's vary that much engine to engine. From what I'm hearing this thing should run @ 60 psi just cruising down the road. I tried 20-50wt and did'nt see any difference. The
oil temp runs 190 -200 normally. The engine has great power. Thanks LT.
