Old 07-11-2003, 06:24 AM
Ron61's Avatar
Ron61 Ron61 is offline
Question
Randy,
Could you give me the bore and stroke and also the cam specs, and preferably not the 50% ones but the seat to seat. If I know the lift, duration, and such my program will be pretty close except the torque will be low. The RPM it gives the power and torque at will be right on. I have a 50% spec convertor to convert to seat to seat but the different cams don't seem to use the same grinds so some times that is way off. If youy cam card doens't show the seat to seat then give me as close as you can the total lift and duration and I will see if I can make a close estimate.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
