Leadertape I got my spring fromFord Power Parts in Cali. 562-921-5300. They are building a web site, but are not on line just yet. Take the pump off the motor. Make sure you have the high volume pump. look for the cup or cottor pin that keeps the spring in the housing and take it off and put the new one in stake the plug or cottor pin back in the housing and reinstall. Make sure you have a chromepoly shaft to spin the pump. You could buy a blueprinted HP,HV pump for FFP. You may want to ask George Anderson if he sells pumps already done. I am sure that the oilpump drive is tough on the Disturbutor gear, but check it once a year for wear. when you put the car away for the winter, and while you are doing that, back off the rocker shafts as not to leave a cylinder open the the winter air. This saves valve springs also. FFP have strange store hours, leave a message they will get back to you. Riley Performance might help also, 410-247-3677, Jean or Glen. They are a couple of others but are not too high on my honor list stay in touch Rick Lake
