funfer2 Hi Kevin build your own system and save 4-500.00 dollars. FAST make a top of the line brain for your car. It is very flexable. Heres my system Accell 1200 cfm throttle body. Speed-pro brain, new name is FAST. GM sensors come with the system. I have a wide O2 sensor because of the supercharger. You will need a intake manifold of single plane, I have a torker it's the easyest to work on. Kinsler sells the injector bosses. They sell injector bulk rails. Pressure regulator to control the fuel. 1 line for pressure one for return. Get a 255 liter pump and this will feed a larger motor than you will have. 1/2 line pressure and 3/8 line return to the tank. This will fit under a stock hood. It is a little more in depth than this, If you want to talk call me after 8:00 pm est time and I will fill you in on all the other things on a FI system or go to a good book store and buy the Fuelinjection book and read it for basic info. 732-254-3536 got to go Rick Lake
