Old 07-11-2003, 06:43 PM
fxbill's Avatar
fxbill fxbill is offline
Cobra Make, Engine: Classic Roadster 427, 446 cu in Iron Eagle stroker, Trick Flow "R" heads, Comp roller, Edelbrock Thunder 800 cfm, Eaton posi, Richmond 3.27, Tremec TKO 600
Hi Bob,
The mufflers have two 1 3/4" pipes that are next to each other. Both are louvered slightly and each extends in from opposite sides of the muffler and stops short of the other end by about 1-2 inches. Basically it's a 1 3/4" entrance that goes through the louvered pipe into the chamber and then out the louvered pipe next to it. The design is similar to a standard "turbo" muffler.
I don't know how well I explained it, but I hope it helps. If you go to the JCWhitney catalog on line they have an illustration of it under the muffler section.....Wait.. I'll get the URL for them....
http://www.jcwhitney.com/product.jht...D=5448&BQ=jcw2
OK....that will show you better than I can describe them...
Bill
