I think it will run rough, miss, unless you are in the upper 2000 rpm's.
I'm running Crane's #34SR00006. It's a solid roller, 256/264 @.050", .658" lift on both, 110 lobe separation, in a 477 ci FE (stroked to 4.2"), edelbrock heads, sidewinder intake.
You can run it on the street, but at lower rpm cruising, it misses, a little jerky. The engine wants to be in the upper 2000 rpm's to be completely smooth. But, the engine pulls > 500 lbs torque from 3500 to 6000 rpm's, with max torque 540, and max hp 570.
my cam is alittle bigger than yours, but, so is my engine, which tends to smooth out the cam somewhat.
Crane makes another solid roller, #34SR00005, which is 240/248 @ .050, .616/.637 lift, 110 lobe separation, which should be smoother at lower rpm's. This may be a better street roller cam that you can use, or regrind yours to approximate this.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
