Are you using some type of fuel-air ratio meter for tuning? My bet is it's too lean. I'm running Wayne Presley's EFI stack system, and too rich will cause back-firing through the stacks. Too lean will cause popping and flames from the exhaust. I can cause exhaust flames at will by just turning the mixture knob towards the lean side.
David
http://members3.clubphoto.com/david251117/guest-1.phtml
