Chris,
David from the Willis 100. Listen close to the buzzing sound.
It saying I don't have enough voltage to run the solenoid switch.
If you cleaned all conection than the problem lies in the battery cable. You can use jumper cables to bypass the battery cable. If your jumper cables are not long enough take the battery out of the trunk and place it on the floor close to the solenoid switch.
David,
