Old 07-14-2003, 09:42 PM
Chaplin's Avatar
Chaplin Chaplin is offline
Cobra Make, Engine: Original ERA 427sc, Powered by Gessford
Chopper-
As to your first question, the only answer I can think of is that a pressed fitting is cheaper to produce than a threaded one.
I just installed my remote filter bracket on my edelbrock waterpump and am familiar with your predicament. I followed the directions that ERA supplied with the remote filter bracket (I'm assuming you also have ERA's remote bracket) and it does work. You need to machine/cut/grind down the lower mounting boss on the waterpump to apx. 3/8" (measuring from the rear of the boss to the front) and then your bracket will fit. I used a cutoff wheel and file to do the job and it worked out fine. Truth be told, you could probably get away with leaving the boss 1/2" thick and it would probably work fine. However, I should add that my bolt configuration is as you described- the top bolt goes in from the front and the bottom bolt I did put in from the rear. With the bottom bolt, however, I put a nut on first and locked the bolt in place to create a stud, then put the bracket on and then locked the bracket to the stud with an egg corn nut (stainless by the way and looks pretty good).
Hope this helps.
Replica is not a dirty word.
