Mohuska Your TWM look great. Did you have a choise of ECU's with the TWM's?? What size injectors are you using? I am sorry I missed DVSF3, I will make next year and bring the car. I was looking at the first cobra picture and the Webers are mounted in a row, Dave S. system is mounted side by side. His setup the carbs are at a 10 degree angle into the motor, the other setup the carbs are straight up and down with a different manifold on the motor. Dave S motor is a High riser, is the other a tunnelport?? Could you put a picture of or setup on the site when the motor is done. I am interested in the TWMs but with a twist of blower on top. I already have the FI system with the paxton and want to move to the next level. Thanks Rick Lake
