Lew,
I understood that DMV will issue you the temporary registeration inly after they call Sacramento and get one of the 500 sequence numbers. Since re are NO MORE, for 2003 I don't believe you can get the process started.
However there will be a mad dash to DMV come January 1, 2004.
You got your SPF, so when YOU go for an extensioon it is based on an existing SPF number issued. As a matter of fact in 2002 some numbers went unused.
If someone starts the process now, between July15th and December 31st, they won't be able to get to the first base. They will not be given a temporray registration because there are no more to give. All 500 for 2003 are gone.
TURK
TURK
OBAMA IN in 2012
