flywheel/pressure plate question
I have a 351w engine from the engine factory.It came with the flywheel. The treads seam to be metric as I realized that the standard ford pressure plate bolts did not fit. Where can I get the correct bolts? Also,should there be locating pins/dowels on the flywheel to locate the pressure plate? There seems to be three bored holes that line up with the smaller holes on the pressure plate flange. I want to do this right. Thanks for the help!
