Old 07-16-2003, 11:37 AM
427 S/O's Avatar
427 S/O 427 S/O is offline
Default autolite in-line gasket kits and parts
New remanufactured autolite in-line gasket kits for the 1425 CFM and 875 CFM, high quality KLINGERSIL thermoseal C-4401 gasket material, each gasket kit includes a 1/16 manafold gasket. I also have accelator pump diaphragms, diaphragm return springs, check valves, floats, needle and seats, jets and idle air bleed jets plus, outlet check balls. I will have calabration kits at a later date. new correct size stainless steel body screws (14). I also repair in-lines.
Perry
