Don or Dv...can you help!
Hey Don and DV! I've got a problem. I've got the Mustang II front end and when coming home from a ride. I heard a nose from the front end. After getting home I found out that I lost the screw/washer and rubber top of the shock on the passengers side. I went back to were it happened and found all the parts...that was great. But I noticed after that the passengers front spring is broken...must be the bad roads here. Can you help me out!!
Thanks.
Snake/Gerry.
P.S. I will one day change out the front and rear suspention..but until then I need either one spring to fix the problem or two, to make them even and the same.
Thanks Guy's.
