Old 07-20-2003, 09:37 AM
BANDIT 1 BANDIT 1 is offline
As others have said you must first decide exactly what you are looking for. Because the new to used price is close to the same on all Superformance Cobra's (which you learned in your other thread...), you should get the car you want. A small block, 427 S.O., 460 and 520+ c.i. "stroker" engined Cobra buyer are looking for something different in a Cobra. Let's say that someone talks you into a 500 horsepower small block (they told you that "500 horsepower was more than enough horsepower). You receive the car and you go for a cruise and after a couple of weeks you realize that the car is so easy to drive that you wish you had more power. Now you have to spend thousands of dollars more (unless you do nitrous) and have the engine pulled (mabey the transmission also) just to have the car you wanted first. The same could be said if you wanted to go road racing and you where talked into a 600+ horsepower big block. You would have been better off with the 500 horsepower small block.
