Old 07-20-2003, 07:41 PM
Art Burtt Art Burtt is offline
Cobra Make, Engine: Classic Roadsters 351 Windsor 405 HP
Jack,
I have power right up to the fuse block for rear harness but nothing coming thru fuse block to the engine side. The rear main harness works. I hooked a hot lead to each wire and checked
them individually. The two (hot all the time) wires to rear main do get power. These would power the door solenoids and trunk solenoid and they should have power at all times. The front harness works fine I have head lights parking lights and turn signal/flashers. I the only problem is no power coming out of fuse block to the tail/brake lights or turn signals. I figure it has to be a problem with the fuse block. The wires between fuse side and connector side, look like spaghetti,are not numbered and I don't have a wiring diagram for this anyhow. I figure a new fuse block
that has been checked out is the answer. Incidently everything else on the car functions normally. Every circuit has been grounded. The wires coming from the light switch ,#'s 171 and 141
have power up to the fuse side of fuse block,these supposedy
turn on all lights. If I had a guess I'll bet it's one or two wires that are not connected or are connected improperly somewhere in the fuse block itself.
