Now that we have a rundown of everyones suspension setup, how about some input on your cooling systems? As you may have seen from another post of mine I am having some serious cooling problems. I am using the Arntz/Butler big radiator with a 16" Spal fan affixed to the rear side (I am not using a shroud but the fan takes up most of the radiator surface area). I am using a "tee" type filler in the upper radiator line and have an overflow can plumbed in as well. Engine is a fairly stout 351C with 10.7:1 compression at about 430hp.
Let me know what your running and your results...
