Scott,
Not disagreeing, but--- "IF" the hydraulic fluid got on the disc".
Did the fittings leak...drip,drip,drip. Did a line or the seal burst?
IF the fluid got on the disc, then the disc most likely will need replaced. I've cleaned some minor boo-boos with brake cleaner and the clutch seemed to work afterwords, but a drenching is another story.
DV...Easy to check once it's taken apart
