Old 07-22-2003, 07:07 AM
Art Burtt Art Burtt is offline
Cobra Make, Engine: Classic Roadsters 351 Windsor 405 HP
Steering column switch seems to be okay as it operates front turn signals,flashers,and low and high beam head lights. I found a wire on the transmission harness that was barely stripped back enough to make contact. It was one of the main power wires coming into fuse block on engine side of the fuse block. I repaired that one so I'm thinking this could be the problem inside the fuse block itself. It is almost impossible to see which wire goes where
even if you pull the fuse block apart. This wire supplier leaves a lot to be deisired in the construction of his product.
