Old 07-22-2003, 09:08 AM
zipzip's Avatar
zipzip zipzip is offline
Cobra Make, Engine: Midstates work in progress, personally built 302
Jim's correct - the timing chain cover will accept either rotation pump. I believe it was around 1983 that Ford started changing to serpentine belts, which changed the pump rotation and therefor the inlet location. BTW: FMC p/n M-6059-D351 is the cover
My cover just had a freeze plug in the dipstick hole. A few raps with a drift and out it came! I then re-used the plug for the hole in the block (rear on driver's side - between cyl's 3 & 4).
What is the problem that caused the question?
You might be a redneck if you think the National Anthem ends with "...Gentlemen, start your engines."
