07-23-2003, 10:32 PM
Ca
Cobra Make, Engine: Classic Roadster 427, 446 cu in Iron Eagle stroker, Trick Flow "R" heads, Comp roller, Edelbrock Thunder 800 cfm, Eaton posi, Richmond 3.27, Tremec TKO 600
Thanks Don.... I'll take the used hot coated set for $450. Will call you Thursday or Friday to arrange pmt. and shipment. Do these have the same mufflers as the new set of unpainted?
I appreciate it....
