Old 07-24-2003, 07:05 AM
rdorman's Avatar
rdorman rdorman is offline
Renegade Nuns on Wheels
Default Pads and stuff
What pad are you running now Ernie? If you want to try the cooling route the mist needs to be very fine and far upstream. Correct temperature range pad would be better! You mentioned dual use with the wilwoods pads. Any compound aside from the T and Q compounds will put out mounds of dust. Many will have excessive rotor wear on the street, they need to operate at there designed temperature. They will also stop like you just can't beleive. There is such a significant difference in the CF of some of these pads that you will have to get your bias set right for each set.
There is no need to take a stab in the dark on the compound. Lets talk.
Rick
OhioCobraClub.com
LondonCobraShow.com
