Old 07-24-2003, 01:42 PM
Chifo Jr Chifo Jr is offline
Just as an adder to the comments above. I found electrical tape wrapped very tightly will help in bringing the cut hose down enough to make installing the fitting over the end much easier. Also a bit of WD-40 to the inside of the hose and on the threads of the fitting helps alot. With a little practice you'll become a pro.
If you havent purchased all of your hose and fittings yet, try G&J (or J&G) aircraft supplies in Ontario, California. They have the lowest prices I have seen on top quality components.
