Old 07-25-2003, 01:53 AM
fxbill's Avatar
fxbill fxbill is offline
Cobra Make, Engine: Classic Roadster 427, 446 cu in Iron Eagle stroker, Trick Flow "R" heads, Comp roller, Edelbrock Thunder 800 cfm, Eaton posi, Richmond 3.27, Tremec TKO 600
Motorsport B303 or E303 roller cam....under $200....big bang for the buck.....Stay away from the F303...it's a supercharger cam and not ground for normally aspired engines. Edelbrock Performer RPM or Weiand Stealth manifold...decent low end and strong all the way to 7000RPM...under $200...( check for hood clearance depending on what air cleaner you have.....mine was tight...).. Edelbrock 1407 750CFM carb...Simple and effective...$220 or $175 factory rebuilt on Ebay. Motorcraft windage tray....about $60 and good for around 15-20 hp..
That's about $650...You can find GT40 heads on Ebay for around $500-$550 or buy a new set of Roush 180 or 200 heads for around $800....all in all not too far from what you're wanting to spend, but an awful lot of horsepower gain.
Regards,
Bill
PS...That's a good deal on GT40 heads from Hawaii Racing!
