  #47 (permalink)
Old 07-26-2003, 06:32 AM
milner351 milner351 is offline
Cobra Make, Engine: Still Dreaming!
Talking more shop talk
Now you're going to wish you never got me started!
I'm thinking of paying the $$ once and for all to have icynene brand expanding foam insulation sprayed in directly on the back side of the steel siding. It fills all the cracks, seals things up tight as a drum and gives a great R value by doing so. AND - no critters, mold, etc, can get into this stuff, AND it has a fire rating, so you don't have to cover it if you don't wish to - like in my case against the roof - that open truss area leaves room for a 13ft high rise two post lift!
Air lines:
some say pvc is a no go
why?
burst pressure on sch80 (gray) is over 350psi
Even my big new IR 7.5hp 80gal 2 stage knocks off at 175psi
AND
there's no rust getting into your air?
what's your take on it?
I was thinking 1" line with as many drops as I have patience to run.
Like the compressor idea, I think I'll hide mine under the stairs to the loft, where I'll hide the furnace and hot water heater, (I hope to put in a bathroom with a shower) and the parts I just can't bear to get rid of.
Do you know where I can find out more about those lights?
I call the previous owner of this place "sparky" I've already rewired the entire house sytsem and run 200amp underground service with a 100amp feed to the barn, now it's time to rewire that.
Well, I could go on forever, keep in touch and let me know if you know anyone interested in the drag car!
