Old 07-26-2003, 09:48 PM
fxbill's Avatar
fxbill fxbill is offline
Cobra Make, Engine: Classic Roadster 427, 446 cu in Iron Eagle stroker, Trick Flow "R" heads, Comp roller, Edelbrock Thunder 800 cfm, Eaton posi, Richmond 3.27, Tremec TKO 600
Your block would be fine for a 408 stroker and you'd still have gorilla pulling if you cammed it right. Scat makes an inexpensive crank that requires very little clearancing in the block to make up a nice stroker...
