Old 07-26-2003, 11:22 PM
fxbill's Avatar
fxbill fxbill is offline
Cobra Make, Engine: Classic Roadster 427, 446 cu in Iron Eagle stroker, Trick Flow "R" heads, Comp roller, Edelbrock Thunder 800 cfm, Eaton posi, Richmond 3.27, Tremec TKO 600
I don't think anyone is putting down the 427 stroker....it just takes less clearance for a bit smaller stroker and the power difference is not that great. I notice you're running a 393....not a bad stroker motor either!
