Old 07-27-2003, 06:10 PM
Tony Radford's Avatar
Tony Radford Tony Radford is offline
Cobra Make, Engine: Unique 427 SC, Southern Automotive 427W Stroker
J.P.,
Your situation sounds interesting (in an unfortunate sort of way). I'm running an unstroked Windsor and the temp is extremely stable. I run mine pretty hard and the temp remains constant regardless of whether I'm idling or screaming through the gears. I recently installed a 16" Spal puller fan that I'm running on a thermostat though it ran pretty cool with the 12" is was running before. I would be inclined to agree with a water pump problem, a slipping fan belt or something simple.
After a good hard ride.....oil pressure is over 50, temp is below 190, she idles and no new dents. LIFE IS GOOD!
